TheMariner
A Monday morning or a Friday afternoon usually
I don't think something like an Output Shaft would be cast. It's more likely machined from hot-rolled bar or from a forged billet.
Here's my 2c worth...
In my opinion the failure is because of 1 of 3 possible reasons:
1). Failure of or no material QA performed before being machined. The hot-rolled or forged billet had a processing fault in it that wasn't found before the part was machined, hardened, & ground. This is unlikely because every shaft is breaking in the same way. Rolling or forging faults are usually more random.
2). Poor material choice and/or heat treatment. The material isn't strong enough for the job at hand in the first place or the heat treatment is too savage leading to brittleness.
3). Design. Machined-in stress raisers that play havoc with fatigue resistance that'll eventually lead to fatigue failure. Rotational bending is a high-risk condition that is bad for fatigue resistance. Throw in shock loading & the occasional reverse bending & it's a nightmare for Designers.
The pics of the broken ends all look the same... 3/4 of the annular breaks are a dull, grey, flat-ish surface & the remainder is a shiny jagged surface. To me, that says fatigue failure. The dull grey areas have been cracked for a while and fretting together (hence the kinda smooth surface) but there was enough solid shaft left to still hold it together. When the cracked area gets too big, the remaining solid shaft isn't strong enough to keep it together, so it breaks suddenly. This gives a shiny, jagged break.
What allowed the shaft to fatigue is the next question. If it's a design error, then we'll all be in trouble eventually... not just some of us. Because it's a bit more random, I think it's either a physical machining error that should have been identified in post-machining QA; it's a heat treatment problem; or a combination of both.
The interesting thing is that BRP are able to narrow it down to individual Spyders for the recall (thankfully, not mine) which, to me, indicates they know the actual shaft UIN (Unique Identifying Number) involved. UIN's are not usually applied before machining & heat treatment.
I may be wrong :dontknow:
Is anyone aware of this problem happening to bikes outside of the Engine Output Shaft recall range (2017-2019 RT & F3)?
My 2016 STS with 33,000 miles broke down last week and needed to be towed home.
I have yet to get it towed to a dealership for inspection, but having taken off several left side panels, what I can see is that the front pulley is spinning under slight acceleration in 1st gear.
Sure, it could also be the front sprocket issue, which also did not include my specific model.
FWIW, I had a short call with BRP in which it was mentioned that there've been reports of possible Engine Output Shaft issues with other bikes outside the range of the recall, and I was advised to get it inspected and repaired, and then contact BRP for possible "exception warranty coverage". Yikes!
Thanks, Ron... I'll take a look to see what I can. I'm not sure how much is visible without taking too many things apart.
I got a call yesterday from my dealer. I am to bring the bike to them in the Spring. Right now it is -30 C and the bike is in storage till Spring.NAAAH OT /\/\ they borrowed the same guys from the electric design group that designed the new 2024 instrument cluster *** to do the machining and QC test because they let the machinists have lunch on Fridays and Mondays... or whatever! lolol
On topic - Agreed with TheMariner above, too much heat treatment leading to brittleness along with stress risers = a fault waiting to happen. But with random testing, it wouldn't get caught. So BRP has narrowed it down to certain days/shifts etc, ergo the certain lots and UIN that could be affected.
Didn't they use the 1330 in other vehicles too? Bet the same issue exists there too, at least for certain UIN and build dates...
Has anyone had the safety recall done and had the shaft replaced??
