McGone
Will this fit in the SPYDER?
http://www.motorcycle-usa.com/79/13...25CR-First-Ride.aspx?WT.i_e_dcsvid=2033704778
The Helicon 1125cc engine is extremely compact and benefits from three internal counter-balancers that keep vibes down.
Putting the bike in motion is an 1125cc V-Twin (built by renowned Austrian engine manufacturer Rotax to Buell specifications), that sports all the features a high-performance engine requires; liquid-cooling and 8-valve, DOHC architecture utilizing a Formula One-derived "finger follower" valve actuation system claimed to reduce friction and allow for faster valve open-and-closing time.
Internally the two pistons are separated by a narrow angle of 72-degrees and slide within a 103 x 67.50mm bore/stroke. Fuel-injection feeds two 61mm throttle bodies and the gas/air mixture is pummeled to a respectable 12.3:1 ratio inside the engine. Three internal counter-balancers help mitigate vibration generated by reciprocating inertia, while a dry sump engine oil lubrication system helps keep mechanical losses to a minimum.
