bump skid wiring
SmokenJoe
Can someone please take a picture of where the plug for skid plugs into please. I was given a skid but no wiring or plugs.
TIA
The wiring comes out on the RH side at the rear of the skid... Run it up through the bodywork to the upper A-arm, and then over to the wiring that lights up your front fender marker light...Easy-Peasey! :D :thumbup:
Still searching for the right wires. Every time I hook up to something and turn signal flashes so does the skid lights????????????? :banghead: Maybe wire colors will help? What am I doing wrong?
:shocked:Can you see the wiring that runs up to the marker lights on your right front fender? :dontknow:
You don't need to look any further than that. :clap:
:D Well: you found the right wiring! :roflblack:
Is the little light at the very front of your fender also blinking, when your signals are on? :dontknow:
Yup! you just need to find something that isn't blinking! :2thumbs:
Sorry for the confusion: I hadn't figured on all of the additional blinking lights on your bike: what else do you have that doesn't blink?
Gotem all hooked up. Just as you said. Fog lites were the easiest to get to.
OOOPS
