Richardv
Hi,
During the hot summer days, my 2013 ST started to have idling problems after a restart when fully warmed up. i.e. 100 miles on a +80°F day. Happened 10-15 times. I used to give a little bit of throttle for 10 - 15 sec, and all was fine afterward. Last time, after the restart, it died and I restarted it right back. It backfired and started. But it sent a blue pop that smoked everything around. I stopped it, checked the oil, restarted and drove home. About 10 - 12 miles. It was smoking slightly. No error code. Added 1/2 quart of oil....but might have been low before the happening....
Brought it to the dealer, who diag a stuck opened evap valved. He road tested it for 12 miles, and called it fixed. Explained the blue smoke with too rich of a mix.....because of the stuck opened evap valve.
Since then, I did 250 miles and it took more than a quart of oil. ( Amsoil 10W40 metric). Obviously, burning oil. It still puff blue at cold start-up, and when taking off on a corner after a complete stop, especially if I "lug" the engine. ( RPM dropping around 900 - 1000, during clutch release. Yes, SM5)
Am I right to suspect a busted valve seal, or even a broken oil ring ? Because of that backfire?
Thanks in advance for your input on the possibilities. I want to make sure that it is fixed correctly, this time.
(P.S. the spyder is covered by an extended warranty, Cornerstone.)
