Buying advice for someone new to cycles
Preventative maintenance will prevent or put off that front pulley problem. There is an improved version available and on newer F3s. At only 4K miles, I pulled mine and lubed it with Moly Paste. It appears the factory did not use that appropriate spline lube.
