Tarzan
I am assembling my engine and have installed the chains and tensioners. With timing set correctly. When turning the crank by hand the tensioners back off and the chains slip. So it jumps time. I ordered new chains and tensioners and the new tensioners are soft just like the originals. I’m not sure if I can dunk them in oil and pump them up. And will they stay pumped up long enough to get it running to build oil pressure. It doesn’t make sense. How are you supposed to make them work? I’ve never seen a set up like this. All the engines I have built have tensioners that hold pressure.
Any help is appreciated. TIA
Rick
Rick
