Can I add heated rear grips to my 2015 RT?
The wiring to the seat is to the passenger detection switch that senses when you have a pillion aboard.
And if it detects a pillion passenger (or any weight/tightly strapped down item) that's putting anything more than about 15-20 lbs of force onto the seat, it ramps up the VSS intervention a bit, bringing it in a bit sooner/more effectively so that you don't throw your passenger into the weeds at the first tight corner, or toss them over your head when you stomp on the brakes to avoid the truck turning left against a red light as you go thru an intersection... 🤨
Can I add heated rear grips to my 2015 Spyder RT and also what is the wiring harness that goes into the seat for?
Yes. You can add heated grips. Oxford makes what is considered the best aftermarket grips available.
