bluestratos
If anyone was following my thread about the HID issues I was having you will know that they started to strobe, then blink out and stay out. Does anyone know if the CanBus needs to have headlight bulbs hooked up? If not, I can still use the HID's if I power the relays off of the accessory fuse panel I installed. When the bike starts the panel will send power to the relays, when turned off then the headlights will go out. Pretty much the same as stock by no delay after stopping.
Thanks
Thanks
