That plastic tank is the overflow/reservoir/recovery tank, and it sounds very much like that level is the 'normal' cold level you should be checking for - altho it might be up or down a bit depending upon your local ambient temps. The level is good just so long as it's above the
LOW mark on the side of the tank when you check it first thing in the morning before starting the engine! :thumbup:
As for that little bit of 'coolant around the outside upper rim',
most likely it is either left over 'spillage' from when it ejected the last of the 'too much' coolant you added before; or it's just a little that's been caught in the seal & come out of the rim of the cap when you took it of to check or add.... a
little coolant around the outside upper rim if you take off the cap isn't usually something to worry about - it's generally just that you can see it due to the contrast on the plastic in a way you couldn't ever see it on a black metal radiator filler neck.... generally!
That said, waaay back in the early days of Spyders, some of those early Spyders had tiny cracks develop in their placcy tanks - some around the filler neck, some around the hose entry &/or seams in the base, so it might pay to keep an eye on it?! But that is meant
EXACTLY the way sounds - you should
ONLY ever keep an
EYE on the coolant level! :shocked: You really shouldn't be taking the cap off that overflow tank to check it....
EVER!! The
ONLY time you should ever take the cap on that placcy tank (
OR the radiator for that matter) is to actually
ADD coolant, and if you don't need to do that (and you shouldn't, not unless your Ryker has
actually over-heated!) then you only ever check the coolant level using your Mk 1 Manufacturer issued eyeball - with any necesary eye-sight correction &/or the help of a bright light (shining from below/behind if at all possible!!) :lecturef_smilie:
This is because these modern 'recovery type' cooling systems are pressurised, so every time you take the radiator or over-flow tank cap off you are increasing the risk of compromising your cooling system's ability to maintain an appropriate pressure; and therefore increasing the risk of failure! :shocked: This is especially the case with these placcy overflow tanks - they do have a finite life, and the flexing & twisting forces involved in removing/refitting the cap shorten that life from decades to just years or maybe even less!! The overflow/recovery tanks have been included and very carefully designed so that in normal operation you shouldn't
EVER need to take the cap off - the only time that should be necessary is if something has gone wrong, but it does allow for the occasional flushing/change of coolant &/or a top up if for whatever reason your engine has run somewhat hotter than usual and so expelled a little too much coolant via the outlet valve. But for normal operation & level checking, the cap/s should
ALWAYS stay ON!! :thumbup:
PS: the contaminants in only 8 or even as much as 16 ozs of water &/or its ability to degrate the coolant's anti-corrosion &/or cooling capabilities will not have been great enough to worry about unless the 'water' you added wasn't in the least bit suitable for human or animal consumption - so if it wasn't mud &/or radioactive stuff that you added, then it's almost certainly safe to simply forget about it!
