Coolant leak on 2016 RTL - screw type hose clamp on thermostat housing loose!
jjc54
My bike started losing coolant with no indication where and no pooling under where it was being parked. Rate was averaging about 10 oz/2000 miles. I first replaced the cap and it still remained. Took some panels off and found a screw type hose clamp that I snugged up. Checked today after approx 1600 miles and the level has not changed. The clamp was on the hose that comes from the reservoir to the thermostat housing (housing end). Fingers crossed!
You probably have it!! Someone's been in there because BRP don't use a screw type clamp on anything, not that they shouldn't, just saying! Good Luck!!
