I was curious if anyone could recommend a great cooling vest for riding? Male and Female.. It's getting warm down south.![]()
We we use the ones from Cycle Gear. They are gray and blue. We took a 3800 mile trip for 17 days from 111 degree heat in AZ to the NWest and I will never, ever go anywhere warm without them. Plain and simple. They work. Under $50 on sale. When they dry out I would use the water faucets and gas stations or water from the cooler.
If you want to go first class, try www.veskimo.com. Pricey but it is like air conditioning.. If you're solo it's OK but two up, not a viable option so the other water evaporation vest would be the way to go. I've used one for years in the summer. You do have to add ice to the chest about every gas stop. And you'll need to wear a heavy coat to insulate yourself from the outside heat. If you can figure that.. It is the same system astronauts use to keep them cool while on the ground waiting.
I don't have experience with one east of the Mississippi but I was thinking that might be the case.In my experience cooling vests do not work in humid climates. I will remove mine east of NM and not pull it out again until I'm back in the desert. In a dry climate they work great.
+1In my experience cooling vests do not work in humid climates. I will remove mine east of NM and not pull it out again until I'm back in the desert. In a dry climate they work great.
Ms Noles, if you're not familiar with how cooling vests work, it is by evaporation. You soak the vest in water and then as you move through the air the water evaporates.
On second thought, get a cotton shirt, soak it in cool water, put it on and go for a ride. If it cools you down any you will know it. This should give you a good idea if you want to try an actual cooling vest. The cotton shirt will dry out in just a few minutes but you'll get an idea of how well it might work.
Do you know if the brand was BILT? oops I hadn't scanned all the way down..
I have noticed that BRP did an excellent job with making a comfortable air bubble around the rider......TOO good when it's really HOT.
I have already removed the lower set of little wings and that didn't help much. I noticed that a couple of my riding buddies have windshields with the 2 cutouts near the bottom that match the holes that already are in the mounting bracket.
Will those 2 holes help that much ? (Maybe I should ask them for a test ride.)
If not, does anybody make an add-on air deflector that mounts relatively easy and doesn't look "cheap" to get me some more AIR behind that shield ??
Looks like the initial question has been answered so I'll ask a related question:
Without enough air flow ON the rider evaporative vests won't work very good; might be even hotter after a short while.
I too am in Florida where it is HOT and humid most of the summer.......starting now.
