Correction to my post about T40's only on both drain plugs
ulflyer
Well-known member
I reported earlier that both my drain plugs used only T40 rather than one using T45. PMK later reported that if you take the T45 socket and tap it in lightly with a hammer it fits perfectly.
He's absolutely correct.
I went out just now and tried it and it works. Apparently, for some reason, the main drain plug is pretty snug and it take some help to get the T45 in. Once tapped in, it fit nicely thereafter. By doing this, I found a small drip coming from that plug and with the T45 I tightened it a bit more.
Thanks PMK for telling us how to do it. :clap::clap:
