Could I be the 1st? CVT Belt Replacement
RykerUSA
Just had a warning light come on that is a "!". Then across the screen scrolled, Transmission Maintenance Required. Yep, Apparently time for a new CVT belt. Fortunately, I have one at home as well as the required tools. Good project for some evening this week.
Incidentally, I have 11,000 miles on my Rally.
Actually changing the belt is a piece of cake, 5 minute job. Getting to the belt will be more time consuming. The seat mount needs to be raised, a bit of a job from what the youtube videos show. The clutch cover needs to be removed...... Just a bunch of bolts...easy enough.
I will be doing fuel filter and spark plugs at the same time as CVT belt replacement. Sounds like an interesting morning.
As I mentioned on another post, I received a transmission service warning flashing across my screen. I have 11000 miles on my Rally. I changed the belt this evening. My original belt looked amazingly good. No signs of excessive wear. Still within service limits of 1.44".
So, my conclusion is that when that warning light goes off, no need to get too worried or in too much of a hurry as your belt probly has hundreds if not the couple of 1000 more miles on it.
My 2 cents..
I wonder if it is simply a mileage trigger and not necessarily a true wear indicator. Is there a Reset Process for the warning/service notification?
Yeah, takes a while to dig down to the clutch area. I tried to find the youtube video that talks about raising the the seat frame, gas tank, etc area (that whole area lifts up to access the clutch area) but I couldn't find it. I assume that's the biggest PITA with the belt change? That and removing 30 screws that hold the plastic housing cover on.
I am curious if the pulley can be moved with just a bolt of if you need the BMP tool. The only videos I can find are for different BRP models. Also a manual I bought on ebay says the belt width can not exceed 36.7 mm or have cracks etc. I wonder if the code could be cleared by disconnecting the battery?
