Laila's Dad
Hello all,
I am honored to share another day that was not promised with each of you...I have a 2012 RSS. I recently added the RAM-B-272U to the left side of my dash(I chose the side because the plastic is harder there on the RSS than in the center where the safety card is). I used the RAM-B-201U-A as the arm and used a 9mm screw/nut and placed a rubber washer under the screw and one on the other side with the nut. I previously had the phone on the handle bar using the x-grip with a different set up but felt that the phone sticking up took away from the look and that the phone had no protection up like that. I switched from the x-grip phone holder to the RAM-HOL-UN4U /RAM-B-238U set up with my dash project. The set up seems sturdy and that is without loctite...My question is, can I do anything extra to reduce vibrations? I guess I thought the vibrations would be minimal. It isn't a "violent" shake but it is noticeable while riding more than I would hope for. Any suggestions are appreciated. Pictures are attached. Thank you in advance for any feedback.
Grady... b.k.a. Laila's dad
