Difficulty shifting down to 2nd gear when at running temperature - any ideas/information appreciated?
Kevin
I have a 2010 RT-S with a full manual transmission. Recently, I have been having trouble shifting from 1st to 2nd when at running temperature. It shifts into 1st without difficulty, but when shifting from 1st to 2nd, occasionally it takes multiple attempts and frequently requires shifting back to 1st before attempting 2nd again. All other gears shift without difficulty. The clutch is working as expected. When cold, shifting is normal, no difficulties. There are no unusual noises and no error codes. Any information would be appreciated.
The clutch is hydraulic and needs the same maintenance as your brake fluid. Check the reservoir and flush the system. I wouldn't be surprised if its been in there for 15 years.
Also, those who put the fat foam grips on manual bikes reduce the throw on the clutch lever. That can keep the clutch plates from fully disengaging. A little drag goes a long way. Especially in the leap from 1st to 2nd.
Lastly, the master or slave cylinders can go bad. But I'd start with a flush and bleed.
Thanks for the information. I've never gone in to changing the grips, but the point about the fluid is definitely something I will look into. I'll need to look up where the bleed screw is and get properly set up to flush and refill. It is very likely that the majority of the fluid is quite old. Thanks again.
