Probably second to the rear complaints but if you were a built for purpose front with about a 95% chance from factory of being forced into misalignment you'd have some strange wear patterns too I would suggest.
Mileage wise I think they have it spot on if you care about any sort of dry cornering grip but if all you want is not to have to pay for that grip and don't need it then by all means select something with a harder compound.
How much sidewall do you need, are they built for load carrying,comfort, sport riding, two up, solo,fast, slow,hot, cold,on road, gravel.How anyone can point blank say the sidewalls aren't correct and the best alternative is something overengineered for the job doesn't make a lot of sense.
Why don't the fronts wear a bald patch in the centre if the sidewalls are inadequate same as the rear?
opcorn:
