Engine RPM Limiter
Wildrice
Lower right corner shows F3 engine RPM limits. Using some common sense would imply that maximum rpm limit is not intended for an extended period of time.
attachment.php
Very early on (2008) a couple that advocated driving and shifting at redline, both ended up with blown engines. Coincidence???
The same numbers are in the 2014 RT service manual. Can't speak for U.S. cars but rev limiters have been common on many European models for years. Just makes sense IMO.
"Using some common sense would imply that maximum rpm limit is not intended for an extended period of time."
I have a ringing ear problem as is. Rare it is that I shift at Redline---I didn't write the book--Can Am may be able to help you grasp their intent....
