F3 Belt length
Don't know..!!
Really long belt with a really big sproket. I think if you get a flat you can ryde home on the sproket..:roflblack: check cheapcycleparts.com. I know they will give you the sprocket size and optional sizes not sure they give the belt demensions. Check online owners manual if you don't have one...:dontknow:
The larger rear pulley on the F3 has the same effect that a numerically higher rear end ratio has on a car. More leverage for the engine to work against so more torque applied to the road.
Net effect is faster acceleration while using more RPM. A gain in mechanical advantage.
