Classic Ontario Government! Well, I don't feel bad about going and doing the test now. FWIW, if you do need to go take the full M test (with M restriction), these are some notes I sent to a friend about the test:
Google map of the route:
https://www.google.com/maps/d/edit?mid=1q-umcCVkfYBq550Wj488B8tFhIIQNzIy&usp=sharing
I've put some ? icons in the map (in red) with some notes in each of them (click on it) of things to watch. Here's my general tips:
When you get to the drive test center, M tests do NOT register at the kiosk. Go right to booth A and the person there will hook you up. You will need your license AND your license plate number (do not need ownership). I got there 30 mins early (it was VERY busy) but was processed quickly. After registering, you'll be sent to get your bike and go around back right by the back fence to wait for examiner (you'll see diagonal bike lines here). Chill while you wait.
The examiner and a driver will come and give you an earbud and tell you some instructions - including what to do with the concrete median that separates Walkley (you can stop in it if you need to).
I've put a bunch of notes in the google maps but here's the main ones:
You need to be checking mirrors around every 10 seconds
Shoulder check when changing lanes or starting from a stop
Scan EVERY intersection or drive you pass. They want to see your helmet move
When you pull out into a 2 lane road (ie. turning left from the drive center or left onto Hunt Club, turn into the outside lane BUT then signal and move over to the inside fairly quickly (I lost marks for not moving over quick enough)
Signal fairly early when merging onto the highway (I lost a mark here)
When doing the residential part, they will ask you to pull over when it's safe. They wanna see signal, shoulder check, turn off the bike, use 4 ways (if bike has 'em), kick stand down, dismount and go stand on the kerb. Reverse when told you can pull away.
This reddit post was ABSOLOUTE GOLD for me. I've recounted most of it above here and given you a map but this is worth a read still
https://www.reddit.com/r/rideottawa/comments/ckbzs0/walkley_road_m2_exit_m_license_road_test_route/
