Wildrice
My main vibration sensitivity is in the floorboards. The extra belt roller reduced my vibration by approx 50%. The cork center pads cut the remaining 50% in half. The pads are 3/4" high which fits my leg length, there are 3/8" solid rubber isolation pads available. Attached are 2 photo's of the pads installed. If floorboard vibration is a big issue for you--this will definitely help--the pads are less than $3 each on Amazon --3 pads on each side with spray can non gloss painted. The machine screws are stainless 10-24 or 10-32 Plus washers & nuts. I tried it with adhesive but didn't work.
Darrell
Darrell
