Foam Grip Installation
nealperkins
Foam grips seemed like a good idea for my F3T...until I tried to install them. The instructions seem to indicate they would slip on but getting them over the raised edge seems impossible. Maybe there's a 'trick' to make it happen?
Thanks!
Hand Sanitizer. Really slips great when installing, the alcohol content makes it evaporate when you're done. Really slop it on...
The instructions with my foam grips recommended hand sanitizer. I couldn't believe how easy they went on with it.
The instructions say use hand sanitizer. I installed mine using hand sanitizer slipped on with no problem.
These things must come in sizes! These are not 'sliding' anywhere. Getting them over the rigid end cap would be a major accomplishment. I was thinking maybe you guys were using a hair dryer or some such?
Foam Grips
Neal, I have seen some foam grips that have a smaller inside diameter That won't fit over Spyder Grips,
TRY ( Grab On Grip Covers ) They work well for me..Just Google that brand name
Freebob
Neal, you don't need a hairdryer. Put some liquid soap or one of the other recommendations on your fingers and run it around the complete insides of the grips. They will slide over everything. If that does not work, Freebob may be onto your problem above.
Pete
+1 hand sanitizer worked for me. Use a very liberal amount, never to much just not enough. Don't be afraid to slop so much on the inside of them that they are dripping wet. :2thumbs:
Yes, these are the Grip-On from Spyder Props.
The problem seems to be the outer ridge, of the rubber grip, being substantially larger than the body of the grip. I think the various lubricants will work fine if I could clear that larger ridge!! Do all the grips have this ridge?
​I 'just' had a terrible thought...are these grips supposed to be a 'replacement' grip? Meaning the rubber grips are supposed to be removed first??
Hahaha....no...they go over your current grips.. do your grips look like my photo above?
