Does the rt have a low fuel light? Gased up as the needle was almost on E but it took less than 5 gal. I think it's a 6.6 gal tank....can't find the info in the manual.
Yes it does. But not where you would think. I was leading a group ride last year around the West Coast. Guy behind me also riding a Spyder + cargo trailer and we were getting pretty much the same mileage and range. The night's stop was getting close and the fuel gage was bouncing off E. I kept watching the fuel gage for the light but nothing, so kept going. When we arrived at the Motel, my friend said his fuel light was on for the last 15 miles. It was then that I learned that the low fuel warning light is on the tach., not the fuel gage...pps:
What year RT are you driving? My '13 with the 998 gets about 150 when the reserve light comes on, but I have got 180 or so when it ran dry. Carried a reserve 1 gal REDA can to test run dry and restart process. Bike was doing 60 when the engine shut down, coasted to a safe stop on the shoulder, poured in my spare, restarted and ran fine back to the nearest gas station. Took 6 gallons to top off, another gallon in the spare REDA 1 gallon can.Does the rt have a low fuel light? Gased up as the needle was almost on E but it took less than 5 gal. I think it's a 6.6 gal tank....can't find the info in the manual.
thank you...that helps....interesting ......was also trying to figure out setting the trip meter...it seems set it to pause to go..to resume to stop :shocked:
If you want more accuracy for the fuel left, disconnect the analog gauges and use the digital ones (engine temp and gas gauge) on the speedo display.
The analog fuel gauge on my '17 RT seems to be working perfectly.
And I can actually SEE it without my glasses on.
If it ain't broke............![]()
He has 2013 and the analog gauges are not that great back then.
I know that but everybody might not.
So......if one is going to give the advice that the analog gauges should be disconnected, it seems to me that the responsible thing to do would be to say "if you have a model prior to 20XX".
If you tell us what year and model Spyder you have it makes it faster for some of us to zero in on possible answers to your questions.
If you look in your operator's guide table of contents you should see a listing for the Multifunction Gauge Description. Click on the page and you will see a picture of the analog speedometer and tachometer in which there are also pictures of all the warning lights that appear on the gauge. The low fuel light should be at the 6K RPM point.
