RCWatchman
I am working on a 2010 Spyder RS SE5 with very low miles on it. It has been stored in a controlled environment, all fluids have been replaced, new battery, and one leaky fuel line connector at the fuel pump. I need to clean the fuel injectors. It appears I must remove a part of the fuel rail on each side of the throttle body to get at the injectors. In the exploded parts view of this area, it shows a flat gasket that sits between each fuel rail section and the throttle body. Before I try this, I would like to know if anyone knows if the pictured gaskets can be used repeatedly? Would appreciate any feedback as what to expect. I did a search but could not find anything to help. Thanks for whatever you might share.
