Fuse info needed
shakey
I want to wire a power port, to power my GPS and cell phone. I am not sure if I should use a 10 or 15 amp in line fuse. Any help would be greatly appreciated. If it helps I have a 2013 RT-S se5.
Fse
Do not use a high amp fuse , use a smaller value that does not exceed the amp value of the
gps or damage can acure if the fuse is higher then what the unit requires if the fuse blows that means the unit in questiion could be toast because of too much of amp load.
You fuse for your wiring, which is already there. If you want to go lower on fuse amps, that's okay; but, don't ever go higher.
