Garmin Zumo 595LM - is it the right one for a Spyder?
budvoss
I have always used my phone for directions, but reading over the Forum has me worried about using my iPhone 13promax. I was thinking about buying a Garmin Zumo 595LM to use instead of the phone. I'm just not sure if it is the right one to get for a Spyder. All input would be very helpful
Thanks all
I have a 595LM and like it. If I were to buy new, I would also get the XT. If I were using my phone, it would not have survived the thunderstorm I got caught in last week. The Garmin did.
Have heard lotsa good comments about the XT! Is mounting for either or both of these easy, maybe even come with a suitable mount? If not, does anyone have a recommended mount to go with whichever is their choice unit?
I have the Garmin 396. To upgrade I would get a Garmin XT.
The systems come with basic handlebar mounts
I had a the Garmin 590LM for several years (pretty much the same as a 595). I've now got an XT and I've got to say it is a lot better so agree with others that if your going to get one get the XT
Both come with standard ram mounts and the bracket to mount on your bars. though I've fitted ram mounts to my dash as I prefer the screen to be fixed not moving with the bars. These are the bits that came with the XT:
The XT doesn't come with a car mount kit but as most cars have built in GPS now its not really an issue. I never used the 590 in the car.
The Zumo 595 is a solid unit. If you can get a good deal on the 595, go for it. The XT has a better display and wifi but they dropped support for the VIRB and TPMS.
Bottom line: XT is the latest & best display if you don't need the camera or TPMS functions and you can find it on sale.
Yep the screen is better and more responsive but the biggest difference for me with the XT vs 590/595 is the software and connectivity.
If your creating complex routes like me then the XT has some big advantages in this area.
590/595
For complex routes you end up using Garmin Basecamp software.
This has to be installed on a Windows or Mac PC/laptop, and to transfer any route to your GPS you have to connect it with a cable to the laptop. This means I normally have to take my laptop with me to do updates when doing a trip that may change or when the iron butt event I'm doing doesn't disclose the checkpoints until a couple of hours before the start.
Basecamp is comprehensive but complex and fiddly when compared to google maps etc. It feels like it was designed in the 1990's.
XT
This connects to your wireless network and will receive software/map updates automatically when turned on. It gets new/modified routes in the same way. If your wireless network covers your garage you can leave the GPS on your Spyder and just switch it on to receive any changes. It also helps that the battery on the XT actually works, unlike the 590:-)
To plan routes you use Garmin Explore. From a PC, Laptop, phone or tablet you can access the Garmin Explore web site and plan routes there. There are also dedicated Garmin Explore Apps for apple and android tablets and phones. This means when I'm travelling just having my phone is enough to create and update routes.
Garmin Explore doesn't have some of the fancy stuff of Basecamp, but its faster, easier and the syncing is automatic. There's still a learning curve to get the best out of it but not as much as Basecamp. The maps themselves are nicer with proper topographical, google and satellite options.
Routing and GPX points
If you've not used software to plan routes on GPS devices before, one thing to be aware of is that when Basecamp, Explore, etc send the route to your device they are only copying the points you've specified not the roads themselves. The GPS device it recalculates the route from those points based on the preferences setup in that device.
If there is a choice of roads and you want to use a particular one its worth putting one or more on these roads to force the GPS to use the right ones. For example I have dirt roads setup as avoid on my device as I don't want it sending me off down them at random - we have a lot of dirt roads in NZ:-) However sometimes if you don't use them you'll end up doing a big detour, so for the instances I'll add a couple of extra points along the dirt road to force the GPS to use it.
Absolutely, Piston:thumbup: It is soooooo easy…..pull into your garage, turn off the Spyder, and as long as you have wifi extended to the garage, your XT is automatically updated with the latest software, maps etc etc, ready when you next ride off (if it was the 595 I would worried about running out of battery before the update finished, but not on the XT.) Sure it’s easy enough to do this manually, but it just removes one of the steps. The XT never has to leave your ride……and that screen and route weather/traffic info…..I love mine:2thumbs:
Pete
