Gas Additive
Winter is fast approaching, should I add anything to the gas while it sits ?
Depends on how long you're going to let it sit but the answer is probably an emphatic YES!
I would highly recommend getting the tank filled with a non-Ethanol fuel if you've got a vendor in the area. Most places you can find one. That will make a big difference in itself.
Whether or not you do the Non-Ethanol thing, use Stabil or some other good fuel stabilizer. You need to run the motor with this stabilizer in it enough so that it's throughout the fuel system.
ck out STARTRON on the web, I use in my Spydy and both of my outboards(115hp and 25hp) both 4 stroke. Startron is all the rage in the marine industry--I use it in all my engines,tractors,lawn mower,etc.
Good Luck
I can see adding 3-4 onces (sp) of Sea Foam to the tank between each winter ride (7-10 Days) would be a good practise to get into along with adding a few onces the ride before I change the oil!!! Learn something New every day at Spyderlovers!!!:clap:
Use a good fuel stabilizer like Stabil or Seafoam, and fill the gas tank to prevent water condensation from the cold air. I'd also put the Spyder on a battery tender. There is a more complete winter storage procedure in your manual...but it is a bit overkill, IMO.
I believe that StarTron used to be better at dealing with the Ethanol mixes, but now Sta-Bil has a formula that's also up to the task.
I didn't know that Seafoam was also a stabilizer... :opps:
I'm an IBM engineer and I love to research the bejeezus out of everything I use. It's a blessing and a curse as Monk used to say. Anyway I researched gas stabilizing additives for weeks and the ultimate winner was Star Tron.
If you want the details just say the word.
If Sea Foam is good enough for Lamont...it's surely good enough for me!! I'm getting some today! Thanks...
