Got my Cell Phone Interface Cable
REDSPY
Received my Cell phone Blue Tooth interface cable P/N 219 400 390 today. Installation looks fairly straight forward as this Cable ( see picture) connects to CB module lower connection and microphone connector plugs into GPS cable. I will post update after I complete the install.
RedSpy
I installed my adapter on Sunday. When it came to the rear right side travel case I did not lossen it up as per instructions. I removed the cover that holds the switch for the radio control from rear and with all the other covers removed I was able to disconect lower cable from CB radio then fish out the disconected end then plug the adapter into it. I inserted other end to the original plug. Tookl ess time. Works great. Good luck. You would think that they could show pictures of the right side of the bike that you need for assembly.
