Can you provide that male plug info? Might just order one for future use. Thanks
JayBros:
I looked at the device in your post and think I know how it works, but can you confirm for me just how it keeps someone from taking you GPS.
thanks
campermac
I cant get power from the GPS connection by the seat. I looked for the fuse and the owners manual says Right side #4 but that spot is empty. I had power there for my 595LM and just got an XT. The polarity was reversed on the last Zumo. Does anyone know where the fuse might be?
That makes sense but I switched it on Radio and it seemed to work however in my metal building all I could hear is noise. I gave up and connected it to the accessory lever lock block I have behind the Air cleaner box. It works, I just have to have the engine running.On a 2016. The gps power plug is power through the radio. If your radio works the gps plug should have power when the key is on. I will assume your 2017 is the same.
"click: to see MY SPYDER PAGE
Detailed instructions on my page. I think the 2019 wiring is the same under the panel on the non-brake (left) side under the seat. There is also an audio jack there to put the GPS audio out. If yours doesn't have one, I tell you how to add one.
I have a 2020 Can-AM RT and just bought a Garmin Zumo XT. Bluetooth audio for music is awesome. Question: The navigation audio doesn't go through the bluetoothed speakers on the Can-am. Is this possible? It used to on my old Can-Am and Zumo660. It would interrupt the music and speak nav directions through the bike's audio.
Troop, I'm thinking about adding a Zumo XT on my 2019 F3-S, any recommendations on mounting hardware. Photos of Garmin mounted on your bike?
See item marked as GPS2
By chance do you know where I can find a diagram like this for the 2019 RTL?
Thanks in advance!
