Health question regarding PSA.
wyliec
Has anyone here ever had prostatitis? If you have, how long before your PSA returned to normal?
PSA
Will depend on how bad and when the infection clears up. Can be hard to get a good bacteria kill in that area. 4-6 weeks or possibly longer. Sooner infection resolved the sooner readings will lower.
I had an episode of it beginning on last Nov 5. I took Levaquin 500mg x once per day for 2 weeks. Felt all ok again.
Went to GP for annual checkup on Dec 4th & blood tests were done including PSA test. Result was 6.88 (on the scale we use in Canada) whereas it is normally <1. I have never had a reading anywhere near that before.
So I guess an attack of prostatitis does elevate the PSA reading and it takes more than 3 weeks to return to normal after symptoms have gone. I see doc again on Feb 6 & will ask to have another PSA test.
I don't think there is a single easy answer to that question.
"There are four types of prostatitis. Each has its own set of symptoms and causes."
https://www.webmd.com/men/guide/prostatitis#1
My symptoms were a combination of a few of the items in the first and second type. I'm scheduled to see a urologist this Monday. All my symptoms were gone by the 1st week in January after being on a prescription drug for a week. I'm going because my primary care physician feels it's prudent to see a specialist at this point because my PSA is still high.
The scale used in my the blood test is labeled as 0.0-4.0 for the reference range. My normal PSA has been around .9 for years. In fact the last reading was .9 before I developed prostatitis a week later, the day before Christmas. When my symptoms dissipated with the first medication, the PSA test came back at 24.3, and a week later, it was 14.9 after a second round using a different medication. It looks like it's going in the correct direction, but my primary care physician feels that I need a second opinion regarding how quickly, and if it will return to normal. So, off to the Urologist I go.
:D I hope that your problems are all behind you now...
I also hope that you don't turned into the butt of too many jokes! :roflblack:
Feel better, and good luck! :roflblack:
