Help/Advice needed
Darren111
Hi there all, never thought I needed help since owning my Spyder since 2015 but there is always a first time. This morning I set myself a task to replace day running light bulb due to not working with a new one (changed the left hand bulb a few weeks ago myself with no problems), I started to take screws off panel but unfortunately 2 of the screws have been over tightened (not by me) and when I have tried to loosen screws I may have damaged the head. My question is what do I need to do to loosen those 2 screws so that I can remove panel to get access to replace day running light bulb?
My Spyder is a 2015 F3-S but I thought I post in general discussion due to advice needed on removing damaged screws.
Heres hoping I get some help/advice from you.:bowdown::bowdown::bowdown:
Use a Dremel or similar tool to cut slots in a criss-cross pattern so you can use a flat head or phillips head screwdriver. If that fails, you may have to drill and use an easy out (screw extractor)...
Thanks:thumbup:. Just been to Halfords and bought a extractor set for torx fixings.
