HELP! Digital Fuel Gauge Dead!
Tomline
Fueled up my 2012 RT after last ride to be ready for a Long Ride today. When I started it up I noticed the digital fuel gauge on the right side of the info center was blank! I used a thin wooden dip stick to measure the amount of fuel in the tank and it was FULL! Is there a blown fuse or have I some how taken it out of service? Thanks
Just to clarify, what do you mean by "blank"? Is the gauge graphic itself completely gone from the display, or does it just indicate Empty with fuel in the tank?
One can assume that you have disconnected the analog gauges to make the digital gauges work. If not, then as mentioned above I would check those connections as well. Fuses and sending units first. :thumbup:
