I noticed a small amount of oil under my ryker right where the drain plugs are but I want to pull off the skid plate and have a better look. I have removed the 5 plastic rivets that hold on the skid plate as per the service manual but it seems that the skid plate is zip tied to something underneath it.  The shop manual and it makes no reference to the zip ties but you can clearly see them in the photo.  The zip ties run from the bottom left up and over to the right, in the photo.  When I pull down on the skid plate after removing the plastic rivets it is clear that it is still attached to something, presumably with the zip ties.  Can I just cut them and if so will I have to rezip tie them as that looks like it would be almost impossible to do.
