Hitches
Yes, if the trailer is setup for a pin all you would need to do is call Bushtec and order a hitch pin and lock. I think it is around $100.00?
PIN-HITCH.....STIFF-HITCH
Or for about $ 11.00 you can do what I did......buy a " TIE-ROD " end for a Toyt 4-wheel drive trk.......It works exactly the same way the one from " Bushtec " does but for a lot less money.......The reason the one from Bushtec costs so much is they only make a few of them and this drives the cost per unit way up.......The " tie-rod " made for the Toyt.trk fits about 12 years worth of Tacoma's, so they are making them by the 10's of thousands. I bought mine at Advance Auto Parts.........This type of Hitch is so much better than the standard " Ball & coupler " I wish I could find a larger version to use on my regular trailer ( 2000 lbs. )..........Mike :thumbup:
