how to check fault code on RT?
aka1004
how do you bring up the fault code on RT? it must not be thesame way you do with RS.
thank you in advance.
1. Turn ignition key to "ON".
2. Wait for multifunction display to initialize.
3. Simultaneously press "MODE", "SET", & turn signal button (cancel).
As on the RS, it shows active codes only. Also works by pressing these buttons with engine running...but may set a false P0000 code.
Also note that if a given fault no longer exists, you can clear the code(s) by removing the ignition key.
