I've never heard of anybody trying to clean one ...... If it's gotten GAS in there ... the GAS will evaporate , the charcoal can dry and probably function again ...... but it's a TIME thing ..... if removed I think using a hair dryer might speed up the process.... but be careful about melting any plastic ...... good luck ..... Mike :thumbup:Hi my 2014 rt-s has been hard starting and not wanting to idol. Is there a vidio that shows were and how to remove and clean the evap canister
thanks kenn
thanks kenn
I dunno kenn, I don't think there's going to to be too much out there about 'cleaning' the evap canister, after-all, it's effectively just an activated charcoal filled container with a couple of vent hoses & a drain attached so it can condense fuel filled fumes to extract the dangerous contaminants & drain any overflow or resulting liquids.
Worrying about cleaning that is sorta like feeling the need to pull the exhaust off your engine so that you can clean any film of soot off the inside of that.... :dontknow:
Personally, I wouldn't bother with doing either!!
Have you checked/replaced your vacuum hoses yet? If they are letting air in thru the minute cracks that will form in the OE material over time, & that could well be a large part your starting & idle problems. :thumbup:
All good advice above, but no one ever seems to mention checking and cleaning/replacing the canister air filter. If the air filter is dirty, clogged, restricted, etc., then the evap system cannot function as designed. This would lead to the canister doing its job collecting vapors, but not being able to be purged of those vapors since a clogged air filter would create a vacuum in the canister. You can't clean the canister, but you can clean or replace the air filter.
The Evap Canister is designed to capture VAPORS ONLY from the fuel tank and route them back into the engine combustion cycle through a Purge Valve system. Most Evap Canisters are located ABOVE the fuel tank so no raw fuel can enter this vent/capture/recycle system. But the Spyder has it located BELOW the fuel tank. If any liquid fuel enters the vent hose going to the Evap Canister it has nowhere else to go but down into the canister which defeats the function of the system and renders it not only useless. But potentially dangerous. Not to mention that you need to be careful never to overfill the fuel tank or fill it and park it shortly thereafter as the fuel will expand as it heats and potentially flood the canister with raw fuel.
The canister system is not designed to handle raw fuel. You will usually get a gasoline smell most of the time, (especially when stopped after riding as you heat the canister and raw fuel trapped within).
To ignore a canister with raw fuel in it is not the best way to go. It needs to be replaced or removed.
Location varies depending on year and model ..... Cheapcycleparts.com has Fiches' for all Spyders that will show you where yours is ...... Mike :thumbup:I've been having trouble with this too. Love to fix it. But a simple question, Where can I find the cannister?
I would assume the air filter is close by. If I remove the cannister do I just plug the hoses with a bolt and
small clamps?
Thanks
Chbuck
small clamps?
Thanks
Chbuck
