How to remove pasenger backrest on RT Limited?
SpyRyd
Need some help with removing the passenger backrest on the RT Limited. Looks like it should come off by removing the Torx screws in the rear trunk. Sound right? Thanks
That's where I'd start looking... Get that inside panel in the top trunk out of the way... Anything holding the badkrest in place should then be visible. Good Luck! :thumbup:
You MIGHT be able to download passenger backrest removal and re-assembly instructions from Corbin's website...
Remove 3 Torx from inside the rear trunk, then 2 smaller torx up above holding the plastic 'top' in place just need to be loosened.. then the whole thing will just slide up and out....
Located the Torx screws inside the rear trunk. Looks simple enough...thanks.
:bowdown:
