ARtraveler
R.I.P. Dwayne
I note that there are occasional references to the Spyder hydroplaning.  I have experienced this a couple of times now.  The first time was a bit scarry and the vss kicked in and saved me from something bad.  I also experienced this yesterday while riding in the rain at about 50 miles per hour.  After my first experience, I learned to slow down below 50 and try to avoid standing water to avoid hydroplaning if possible.  I wrote BRP after the first incident and suggested a different tire configuration.  Did not receive a satisfactory answer back other than drive safely.  Hydroplaning is a safety issue, and can cause a bad accident if the driver gets caught off guard.  I believe that tire tread configuration may be part of a solution.  Does anyone know of a better tire for front and back that may be less prone to hydroplaning than the stock tires?  I'll  bet Scotty has some good advice.
opcorn:
