youngers
it is all gone ! :yikes: them Russians ! :roflblack: { o kay not really ... I did my first oil change , } here is the skeletal frame - took the plastic off the night before , took a good look over the whole inner sections , see if any thing was a miss { messed up } .. now I had been looking at the you tubers , on oil change , and every one put the cycle on blocks rise it up , get it up ! I did mine right on the ground , no block , jacks nodda --- but I do have a slight valley in my rock drive way that the oil pan can sit in and the bike has enough clearance for the oil change -------> I have the cycle with the clutch --- S M 5 model one filter ... was pretty easy guys and gals , it did take a little long , too get the plugs out , off the bottom , like they were impacted on my cycle { I think they were a little over torque } here are the photos
I do have a question for you oil change folksters , is this a factory oil filter ? or just a cheepie ...
the one I changed out ! the one I put in has a wire screen in the body so it will not collapse ... { hey while I have you guys here --- how many throttle body vacuum lines are there ? 1 or 2 } and if it is any help --- 1 gallon ,plus one quart or oil ! will watch for leaks ...
