Installed GPS Mount on 2012 Spyder RT SE5 Limited Edition
Toni2c14
I'm new so forgive any errors. In Feb 2020, I bought a used 2012 Spyder RT. A GPS mount was already on it so I contacted BRP and asked which GPS went with this bike. I was told Garmin Zumo 590 therefore purchased a used one on Ebay. Once it arrived, it was clear it does not fit the GPS mount on my bike. Im hoping someone may know which GPS fits this mount so I can but it. Thank you.
Are you saying a Garmin 660 would fit the mount I have? If so. Thank you for this info! Sorry, im new to this site and am fumbling my way around...
Up until some time after 2013, the BRP installed GPS mount was specifically for the Garmin 660. :thumbup:
That said, BRP did take steps to stop people from buying a 660 elsewhere/cheaper, and then readily fitting it onto their 'Spyder unique' mount..... I'm not positive if it's in the actual 'Spyder' side of the wiring, or if it's something they convinced Garmin to do actually in the GPS units themselves that they supplied to BRP in order to make them incompatible with Garmin's 'normal' mounts & wiring harnesses, but I think that they've done something odd in the wiring harness &/or BRP supplied Garmin 660's - something to do with how they get powered via the dock plate on top of that mounting bracket.... IIRC, it's something to do with the pins in the base for power/charging being swapped, but it was a while ago & my 'thorough cursory glance' thru GPS Wiring here didn't give me any better clues.... but it is here somewhere if you search for it! :lecturef_smilie:
Still'n all, if you've got an BRP/OE spec GPS mount on an RT/ST Ltd that's 2013 or earlier, it's for a Garmin 660, and NOT the Garmin 590 - I don't think they 'upgraded' to them until maybe mid 2015?! However, now that you actually HAVE a 590, I reckon you might find it cheaper & easier to buy just the base/dock plate that the 590 clips into, and remove the 660 base/dock plate that's there, wire up the 590 version, & install it instead.... unless you really want to run a 660 or upgrade to something else, anyway! :ohyea:
Good Luck! :cheers:
The 590 is an upgrade from the 660 and like Peter said you may want to change the wires and mount plate to match the 590, it would be an up grade from the 660.
660 not bad unit ( discontinued :sour:)& does pop up 4 sale here every now & then. Usually from someone upgrading to 590 or something, best check with Garmin about (LM) lifetime maps if is per the unit or account maybe a comparison list between 660&590 find what you like better.:2thumbs:
Thank you all for this Info! BRP Rep made the mistake by telling me it takes a 590 but since 660 is discontinued, and the 590 is better, I guess it was the "right" answer... I'll keep the 590 and find a dealership (at some point) to do the change over for my unit. I'm new to all of this and not that mechanically inclined to do it myself. BTW, My 590 came with the mount in box and it is Lifetime Maps. Thank you all again! I'm sure I will be posting other questions soon. So much I dont know about bike and am curious about...
I read on the internet that when changing from a Garmin Zumo 660 to 665, there is a problem on a 2014 RT. I believe that one of the Spyder Lovers members said that you need to remove the mounting plate head on the 660 mount and change it to the 665 mount. Not sure what this is about, but I'm going to upgrade to the 665 on my trike.
Also, I will be installing the BRP CB on my bike with the entertainment harness from BRP. I see that the older radio mounts were different (horizontal mounted) while they're now mounted vertically. I purchased the mounting plates to do that. It comes with 10" extension for the harness cables that makes up the needed length for the harness.
If anyone can help me with other issues needed for the procedure, I would be thankful.
Ps: I've been an inactive member for a long period. Sold my Harley and bought a 2014 RT Limited. I purchased my first Spyder new, a 2011 RT Limited. After putting 47,000 miles on it, I decided to go back to 2 wheels. Now after hitting 80, I decided to go back to the Spyder again. I was a vent
I also have 2014RT. Can't answer your questions, but also thinking of putting in a GPS. I don't know anything about it. But why not a newer unit like an XT or something? Would there be mounting plates and wiring fit for it, or is this only available for a 665?
The Zumo 396 was a breeze to mount.
A bolt with RAM ball replaces one of the handlebar bolts, a short RAM arm and run the wiring up to the unit.
The ball is available on Amazon or from Pierre at canamspyderaccessories. The short arm is on Amazon. I got my unit from GPS city. There is a larger 7 inch Zumo available. Or you may want a Carpuride and use Apple Car Play or Android Auto. They all mount the same way.
