bluestratos
Got her done but it took two days as I also installed a wide angle A/F gauge with sensor and a water temp/volt meter in the dash. I had to take the muffler in to get the bungs welded up so that ate a couple hours. I guess from here the auto tune does its thing so I just need to button the bike back up after my new radar detector shows up.
The instructions they sent were incorrect as there are now 2 additional harness connections that connect to timing and ignition, neither of which were shown. I eventually found theme on the web but that cost me 2 hours of searching.
The wide gauge O2 gauge is great, very steady and easy to read and it matches the look of the water/volt meter although the volt part of that gauge is a bit strange, even thought there are lot of bar around the perimeter it is basically: green is good, yellow below 12.5 (as I programed it) and red would be close to a no start condition.
Once I get it all back together I will report back what changes I notice. If there is anyone out there that has a good handle on programing the power commander I would like to pick you brain
