Is It OK to Make 500 km On the First Day With a Brand-New 2023 Can-Am RT Limited?
esky
Hello Everyone!
I’m new here, so please bear with me.
Greetings from cold Winnipeg, Manitoba! :)
I have two questions, please:
Once the weather cooperates, I will start the break-in period.
On the first day, I’m planning to ride for 500-600 km, with the first 300 km spent riding through the city, as the manual recommends (in addition to the first 1000 break-in kilometres): for the first 300 km, "riding with frequent braking and steering to break in." After that, I will use less busy back roads outside the city. In the city, the fastest speed will be 70 km/h, and in some places, even 80 km/h. Outside the city, it will be 90 km/h.
I’m obsessive about correctly performing the break-in, but I’m also in a rush, as I need to head to another province.
  • Is it “healthy” for the engine of a new bike (2023 Can-Am RT Limited with 6 km on the speedometer) to run for many hours? Of course, I’ll stop occasionally and avoid hard acceleration, will monitor temperature, etc. I don’t intend to “baby” it, but I also don’t want to overwhelm the brand new engine with extensive running time (in terms of hours). Again, I will "avoid prolonged riding maintaining constant RPM," as the manual warns about the break-in process. RPMs will vary.
The next day, I will start my trip of 1600 km (1000 miles), with the first 400-500 km still being break-in kilometres (but at higher speeds).
  • Regarding electronics: When connecting devices (phone, helmet), setting things up in BRP Connect, etc., the bike is supposed to be on. Is it okay to keep the electrical power on for about 20 minutes without starting the engine? The question isn’t about the battery draining, but about whether anything like a relay (or anything similar) could get damaged if the engine isn’t started immediately?
Thank you in advance for your answers!
While it might not be 'ideal' from the dealer's point of view, the 1330 motor is very unlikely to have any issues with it, and you certainly won't be alone in doing that sort of kms right off the bat. Just try to avoid sitting on set revs/speed for too long, vary it up & down a bit as much as you can. ;)
Personally, I wouldn't think you'd need or should leave your ignition on for as long as 20 minutes setting everything up, especially if it's on a new battery that's potentially been sitting around for a while on the showroom floor or maybe it's just been installed... If it's going to take you that long to set everything up, try to break it up a bit, or maybe just connect your battery to a tender/maintainer while you do it. (y)
Follow the BRP guidelines and enjoy the Spyder. I like to vary the RPM during this period by downshifting or upshifting every few minutes so that the RPM is not constant for a long time. Since your machine is new its possible the battery is not fully charged so if you have a small charger hook it up while you are playing with the electronics and that way when you go on your longer ride it should be fully charged.
I'm from Edmonton. ;)
Agree with others , Please double check your battery, there have been reports of dealers using some substandard batteries. Sorry don’t know brand or details, just aware of potential issues. Hopefully someone can provide correct details. Also with battery good to add star washers to terminal connections. Congrats Enjoy.
A nice ride may be up Main St to either Lockport or Selkirk, and return to city via Henderson Hwy or Hwy 59, provided you follow BRP recommendations.
Most modern engines are manufactured with a lot more precision than the engines of 50 or more years ago. They can be assembled with closer tolerances. Different metals are used and different processes, such as cylinder liners. We have access to far superior lubricants. They don't really need much of a break in period. First couple hundred miles it is good to vary engine speed. Just droning on at 60 MPH for hundreds of miles is not the ideal way to break one in. Neither is several hours of stop and go city traffic.
They're your dollars, spend them as you wish, but with the 1330 ACE engine you do not need to change the oil and filter before 3,000 miles. The first thing you should do though is be certain you know the proper procedure, in the operator's guide, for checking the oil level and check it before you put many miles on the Spyder so you have a baseline. The oil will be pristine and you may find the dipstick hard to read so have a piece of paper towel to lay it on so you can verify the oil level.
2024 Spyder RT Operator's Guide:
Page 58:
After the break-in period, your vehicle should be inspected as per the Maintenance Schedule.
Page 120:
5,000 km (3,000 mi) - break in service
The table then shows the following items need to be done at the break in service:
Replace - Engine Oil and Filter
Inspect and Adjust - Engine cooling components (coolant concentration, coolant level, hose condition, clamps, leaks)
Inspect - Brake components and function
Inspect and Adjust - Check the drive belt condition and tension
Inspect - Drive components and function
Tighten - Wheel lug nuts
Tighten - Rear wheel axle nut
Inspect - Operation of control switches and lighting
Inspect and Tighten - Body panels and hardware
Lubricate - Pivots, latches, hinges and key barrels
Changing the oil and filter will not damage your Spyder. It will just cost you money you don't need to spend yet.
Hello Everyone!
Rode mine out of the dealership and 1350 miles from NY to Florida a couple years ago. 2 hour power nap in the Carolinas that was the only stop. So yes, your Spyder will be fine. And it's fine to leave it on for 20 minutes.
It is a water cooled engine, just like a car or truck. There should not be any problems with excessive heat in city driving to worry about. If you are that obsessive when you break in a brand new car or truck, just do the same to the Spyder as the new 4 wheel vehicles. If it was an air cooled engine in the city traffic, you might want to avoid that, but the water cooled engine with the thermostatic controlled temperature, you are just going to be seeing that it runs as it was designed to run.
I purchased my 2024 RTL in September 2024 from Winnipeg to Thompson Mb. No difficulties. I varied the speed and and rpms. Filled twice on the way home ,great gas milage. Topped up in Grand Rapids . Enjoy you Spyder, can't wait till it warms up,so l can ride again for l only have 1085 kms.
I know many will disagree, and this is nothing like the manufacturer, whose main interest is getting it through the warranty period, recommends.
I've never been a fan of an easy break-in period. My main interest is a hard-running engine that will deliver max performance.
I prefer to follow the advice of many successful engine builders.
Any new engine I buy or build will get warmed up, make sure the tune is close enough to not hurt anything, and a 15 minute run-in at varying speeds with maybe half throttle.
After that, seat the rings with 10 cycles of full throttle acceleration in a higher gear to 80% of redline, with a couple minutes of cool-down between each pull.
Change the oil after that and have fun. :cool:
So, I did it! Drove through the city a bit, then hit a local back road on my way to another town for an overnight stay. Later that evening, it got so cold, windy, and rainy that I cared a lot less about speeding…
The next day, I cruised around a bit. Before heading home on April 18, my odometer read 584 km. I started my Iron Butt challenge ride at 5 PM and arrived home at 1:33 AM on April 19.
Around 10 PM, temperatures dropped to -1°C and my right palm started to ache, so I pushed it at 120 - 125 km/h. The bike performed well, and with about 1400 km already on the odometer, I just kept flying.
In better conditions, honestly, I would’ve been more gentle - but in that cold? Goodness! All I could think about was getting home as fast as possible.
The total ride was 1658 km.
I’ll be submitting my records to the IBA shortly.
Got serious blisters on my palm - apparently from the new gloves I bought. I’ve filed a claim. Some friends are laughing and calling them my ‘honor patches,’ but honestly, they’re getting worse over time and still hurt. (Not funny at all. :-))
Still, it was a valuable experience! And I’ve totally fallen in love with long solo rides - I’ll definitely plan more.
