Reviving an older topic in an effort to clarify a few details.
As insight, our 2014 RTS SE6, began having temp fluctuations while idling. Fans operated normal. Then other times, all would be normal, we would stop and shut down for a few minutes. Upon restarting, the indicated temps crept up well above 1/2 way on the gauge, fans came on, temps kept increasing, fans blowing forward, but no heat was coming off radiators. Coolant level was adequate. Expected a failing thermostat.
Removed a few body panels. Removed fasteners that mount computer and set it to the side without disconnecting wiring connectors.
Previously, I had removed the oem hose clamps, so disconnecting the hoses at the water pump spigots was easy. I drained the coolant via the already disconnected hoses.
So to clarify a few things posted previously.
1) Regarding the fasteners securing the water pump to the engine case, none had thread locking compound on them.
2) Concern was previously mentioned regarding the thermoplastic water pump housing being damaged by over torquing the fasteners that secure the water pump. To clarify further, each of the water pump fasteners can not be tightened to damage the plastic. Each fastener has a metal crush sleeve that prevents damaging the plastic housing. Yes, you could overtighten and strip the case threads, but crushing the plastic is addressed with the crush sleeves.
3) During removal, withdrawing the water pump from the engine case, use care as the plastic gear can slide off the water pump shaft. I did not have any issue with the gear dropping into the cases, not sure if it could be dropped, simply be aware.
4) There are no paper gaskets, an O ring seals the water pump housing to the engine case. A preformed packing seals the water passages to the engine case.
5) I did remove the thermostat. My goal was to hopefully replace just the thermostat. Unfortunately, the thermostat had no identifiable part number on it. A trip to NAPA, going thru every thermostat on their shelf found no match.
The thermostat is a typical 2.1” diameter type, 80*c, however the bypass plate diameter would not match anything I compared it too. The system utilizes the modern bypass design. Failing to use a bypass thermostat will cause overheating unless the pump housing is modified, and even that is no assurance if a non correct bypass style thermostat is tried.
So, a new water pump assembly is on its way. I know several folks mentioned replacement of the water pump was a difficult task to accomplish. My opinion found the task was straight forward and minimally difficult.
