Well IMHO General tire hasn't up-dated the Altimax in a very long time ..... so I'm not surprised that it finally did ..... It is going to take a few months to get an honest " performance " picture for the new Altimax ..... I've posted elsewhere my review of the " RIKEN " tire I bought .... I rate it EXCELLENT and it's about $20.00 less than anything else worth putting on a Spyder ...... JMHO .... Mike :thumbup:
Due to the mass of positive reports, I have ordered an RT43. Only 8744 on the original Kenda rear and it is at wear bars on the sides and the wear bars almost gone near the center.
Due to the mass of positive reports, I have ordered an RT43. Only 8744 on the original Kenda rear and it is at the wear bars on the sides and the wear bars are almost gone near the center.
~~~based on your results PID, I should get another year out of my OEM rear tire. I’ve only accumulated 4K miles after 12 months ownership, my 2021 RTL, so that is good news for me, in that i wont have to bother swapping rubber on the rear rim. Thank you for posting this information
Best,
Jake
Reddick Fla.
It’s never too late to have a happy childhood ��
No comment in regards to the RT43, the replacement RT45, or even the Riken on account of no experience riding those tires.
Offering to Shakin Jake, while you should be able to obtain those next 4000 miles on your current tire, consider too that the higher temps of the road surfaces here in Florida, plus the glass or shell filler they often add to the asphalt, tends to have the tires wear faster. The additional heat softens the tire more than other areas and the abrasiveness of out pavement tends to eat tires more quickly. Not saying it will happen, rather your oem Kenda is headed for typical milage often experienced here in Florida. It will get to be a rear tire with far less grip as you use the last half of the tread remaining.
~~~I suspect you’re right PMK, that’s what I like about riding/owning a new bike, you really don't have to concern yourself with equipment replacement, in the short run, but then after that time is up…look out=
I realize reading all the posts of owners with Kenda rear tires (RT Spyders), they don’t seem to have much in the way of longevity, do they?, but again, I suspect you’re right, the next 4K miles on my OEM rear tire will not be as blissful, as the first 4K miles…
On a different note, although i only accumulated 4500 miles on the 2020 Ryker Rally I bought new that year, those Kenda tires wore like iron, and gave a decant level of grip too!
Best
Jake
Reddick Fla.
Entirely your call, but I suspect you will replace that oem rear tire before actually worn out per the wear indicators. Ours just got too slippery and loose to stay comfortable.
Tires are inexpensive expendable items vs a crash or similar. Add to that, quality performance tires do improve how the Spyder feels and behaves.
I helped a friend a while back, taking his 2021 Spyder 150 miles each way to the shop for warranty work. Suffice to say, even though he had replaced his front tires with Fomozas when the oem Kendas were almost new, it still was not cool riding his Spyder with an oem Kenda rear tire after having logged many thousands of miles under me on our Spyder with Formoza fronts and Yokohama rear. That rear Kenda on his 2021 is a sway monster compared to the Yokohama on our Spyder.
~~~I’ll def keep an eye on the traction abilities of my OEM Kenda tires PMK. That said, I have no complaints at this point with these tires, rain or shine. I totally agree in regards to the cost of rubber. Tires are inexpensive, especially considering I have always done my own tire R&R but I’m not of the persuasion of replacing a perfectly good tire when it’s not warranted. I realize there are many Kenda haters here in this board. I’m not one of them, but I will keep a close eye on my OEM tires and if they ever give the slightest hint of less than stellar performance, off they go and on with dark side since the Kenda tire costs the same if not more than dark side tires and yes, I realize the rear wears faster than the fronts. If I don’t get 8 K miles out of the rear OEM tire, boo hoo, off it will go but, not a moment before that time. Others may have better & different ideas
Best,
Jake
Reddick Fla.
“I’m living on Chinese rocks” Dee Dee Ramone
