Is there a jack that will raise the Spyder RT up 24 inches so I can install Baja Rons sway Bar? I have a yellow sears motorcycle jack but will not go up to 24 inches.
Jim
Jim
You'll only need it that high for maybe 30 seconds to 1 minute or so - all the necessary work besides the actual 'slide old bar out, slide new bar in' bit can be done with it much lower! :thumbup:
I've never seen a PitBull jack/stand for the Spyder, but they are still selling excellent gear: https://www.pit-bull.com/.
Jim
https://www.harborfreight.com/300-l...MI35S6q6Px7gIV0MDACh1xIASDEAQYAyABEgJNpPD_BwE
Will a Lawnmower lift work on spyder ones that lift the front 2 tires. they arenrated for 750#
this lift says 300# but they have one for 750#
There is apparent conflicting information in the service manual. Some procedures call for lifting under the rear shock absorber, and some say do not. My interpretation is DO NOT lift using the bottom end of the shock absorber. You could bend the shock mounting bolt. But you CAN lift if the jack spans the entire shock mounting bracket and does not put a load on the shock absorber. That is specifically mentioned in one procedure. If you think about it it's obvious the bracket has to be stout enough to support the weight of the bike that is above the swing arm. When you add in safety factor and the shock from tire movement that is transmitted through the bracket it has to be pretty stout.From what I can tell that jack use's the rear shock bracket for lifting, I was under the impression that was a no no. :dontknow:
Also, IIRC, the section that says it is a no-no deals with adjusting the belt tension or something of the sort where the swing arm needs to be free to move.
The conflict in the manual, IMO, arises from the fact that it is undoubtedly written by several tech writers and design engineers who have not coordinated 100% on all the various sections of the manual.
I don't know if it's the case still, or not, but in years past engineers in Japan had to work the assembly line for a few years before moving to the design offices! And then there is the story I was told about a new combine being designed at John Deere. The company put together a team of engineers, factory workers, farmers, dealers, and I don't know who all. The person telling me about it said the air sure turned blue when the team started to assemble the prototype based on their just completed design!I also believe all engineers should be a mechanic for a period of time before being able to design things so they have a true understanding how things are in the real world.
