Jacking up Ryker for oil change - where's the best jacking points?
JopRyker
It seems like everyone uses different areas to jack up their Ryker.
Where is the best safest area to jack up the front end to put two jack stands under it... and the best area to either leave the jack or put one jack stand under the rear?
Thanks!
I've never used jack stands on the front, so I really cant answer your question on front placement. I've found it easier to just drive it up on a set of Rhino wheel ramps in the front and jack up the rear. I place the jack underneath the rear on the drivers side pivot point on the frame right behind the exhaust can.
