jmstiffany
jmstiffany
I have a 2010 rts se5 premiere edition. I think my rear shock is leaking. Has anyone else had this problem? Can they be rebuilt or do you have to replace it?
There have been cases of the airbag or piping leaking. Before you jump to that conclusion, though, check (or replace) the valve core in the Schrader valve under the seat. That is a common source of leaks.
Scotty, does that use a commom valve stem core?
Teddy & I would like to Welcome you to the SpyderHood
:congrats: & :welcome: You've found the :firstplace: site on the WWW for ANYthing & EVERYthing :f_spider: related:yes:
The leak i have is not air. I am dripping oil off of the bottom shock mount. The whole front of the shock has oil running down it
