Larin Lift
if your just lifting the front end to jack stands I would say its ok..But I wouldnt go much more than that..It looks pretty risky from what I seen of the specs of this type of lift,,
You be better off with floor jacks or motorcycle lift,,
well then put it under the frame middle I use the left side by the left floor board.
Takes a bit to get use to lifting and jacking the spyder to get comfortable
There are post on where others put there jack..
Don't trust them anymore since my bottle jack broken and bent up my lift..
LARIN LIFT
That looks like the same lift sold by Harbour Freight and Sears. Check their prices. It works on Spyders.
:agree::agree::agree:.....The Larin is just MORE EXPENSIVE than either mentioned by Grandpot...........It appears to be EACTLY the same .................jmho.......Mike :bbq:
All of the above...
should work fine. It is the same principle as what many use here. I think harbor frieght has all the models cheaper than most I got mine from sears for the same price when on sale....:thumbup:
attachment.php
