Looking for the thread on how to preset the radio.
Copperman
I remember reading a thread on how to program the radio because the Operator's Guide is pretty vague. I can't seem to find it. Can someone please guide me to the thread? Thanks
Don't have the link but it is pretty simple ... (you have to be stopped for this)...
Using the MODE button, select AM or FM. Press and hold the SET button. When the display changes, you will be able to use the RIGHT and LEFT buttons to select the station you want. Once on the station, press the DOWN button and you will see the number of the next available preset in the lower left of the display. That's it! Press the MODE button to return to the main display. NOTE: you cannot remove the presets ...
Repeat the above procedure to set the rest of your stations. In use, just press the RIGHT or LEFT buttons to select the next preset station.
Hope this helps!
Hope this helps!
Thank you, and I did not know either.
