Ok folks, I waited to post this to make certain I got it all right for you. I went in with an open mind. I did a demo ride back when the RT came out and I knew a few minutes into the ride that the RT was not for me. I had the exact opposite thoughts a few minutes into the F3 ride. You don't ride on top of the F3, you ride down in the F3. The relaxed seating position allows you to roll through the turns without the centrifical force trying to unseat you.
None of the demo F3's had a windshield. This kind of worried me, when I first got the GS back in 2008 my head got bounced around until I found the windshield that was right for me. There was no problem on the F3. Sitting down in the F3, the wind flows right over the top of you. I had no wind buffeting with the F3.
This Spyder is quick. The throttle is much more sensitive than the GS. Just a touch and you are darting away from a stop. The route we took had us riding some nice back roads. We hit some stop signs that allowed us to spread out a little bit. I am really impressed with the acceleration of the F3. I think it is quicker than the GS. Even in 5th gear you can roll back the throttle and it will show you there is still power there. Make it all the way to 6th and the RPMs drop. Idle was about 900RPM, the GS idles around 1400RPM. I see big gas savings with the F3.
i really enjoyed being able to see the the display with just a slight drop of the sight, the GS you had to look down to check your status. It is right there for you on the F3. All said, I will be selling the GS. The F3 is everything I have been hoping it would be.
Now the downside, the trunk would not even fit my full face helmet with the Bluetooth unit attached. Trunk has shrunk. Did not see any type of place to set up a trailer hitch, but if you plan to travel with the F3 you will need one. Side bags may be a need for this ride but I love it anyway. I will be buying a F3.
