MMcc
I keep hearing people saying that the spyder magneto does not charge at low RPM's and you must run above 5000 RPM to charge the battery. I questioned this so I did some tests on my 2011 RT-S with 6000 miles on the clock. The results are as follows.
Conditions voltage reading
Ignition off, spyder has been sitting for the past 5 days. 12.28 volts
Ignition on, ready to start 12.11 volts
Spyder started, Idle 1400-1500 RPM 14.14 volts
1st gear 2200 RPM 13. 23 volts
2nd gear 3200 RPM 13.54 volts
3rd gear 3000 RPM 13.88 volts
4th gear 4200 RPM 14.07 volts
5th gear 5100 RPM 14.24 volts
Engine at operating temp idle 1350-1400 13.89 volts
Bike shut off after ride 12.32 volts
From my experience anything over 13.2 volts will provide some charge to the battery. The reason for this test is that with the 55 MPH speed limit on the local roads and few freeways around here I do most of my riding in the 4500 RPM range. Most of the time in 4th but if the road is level I will shift to 5th. I have never had to use a battery tender on any of my bikes except in the spring to charge the battery after a long winter of sitting disconnected from the bike. My observations.
